Whats is everyone using for the coolant used in the Heat Exchanger setup? Also how much of that fluid should be used? Do you just fill up the reservoir until its full?
Is anyone using an overfill tank as well or just the reservoir?
I'm not trying to over think this, I just want to get it done right the first time.
Thanks Guys!!!
There is a thread on this, i believe But.
some people are using 50/50 Coolant
Some people are using straight water
10% coolant, 90% water
Im using 10% coolant, 10% water wetter, and 79% water
Your choice dude
Mods: Synapse Charge Piping, Short Throw, Bad-Mab Dp, Dejon Intake, BYT Tuned!
Parts For SALE! Pacesetter Header(ECO),17'in Resonator, Alternator, Starter, Viper Alarm.
Okay man. thanks for the info. are you using an overfill tank?
No i just using the filler neck, But you can go to the junkyard and pick up a a cobalt coolant tank and use that a overflow...It helps bleed the system.
JUCNBST wrote:rams piss...
this
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
ive tried to use distilled with redline water wetter no different results from using reg coolant
I run washer fluid since it doesn't typically get below 0 here in NC
Yup Rams Piss!!! lol
I was seeing if anybody caught that LOL
