I am just getting the parts together to add a S/C to my eco..
But my car has no factory A/C,And i was reading that you need to have the A/C compressor or pully from it to take up the belt slack..So I would like to know Do i need to go that route Or is there a shorter belt available...
Any help would be great,Thanks,jason
I do believe you have to run the a/c belt and use the a/c. But what you can do is hit up pick and pull in chilliwack and grab a compressor from there. Pull the guts and use that as your idler.
Thats what I was figuring...Oh Well Dam Gm thinking we all have A/C.
Yuppers, gotta have the compressor.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
ZZP lists a a/c delete pulley. But when you click on it nothing comes up. Would be awesome if they actually made one
I will check out ZZP,Called them yesterday with no replie..But I will find somthing..Think just getting the A/C pump and pulling it apart will be a fast option..Thanks for the help.
GM had one, but last I looked the part number no longer works at all, and all I have found is references to people cutting up a compressors.
If you still have the part number could you send it my way,Would be great..Thanks
