So I have yet to find actual answers searching so I'll just ask. For those of you running the Eco Saab turbo set up.
1. I ended up with the Garrett low pressure turbo and blue Saab injectors so can I install the blue injectors t map sensor and Garrett turbo and run ok on the gm supercharger reflash?? I don't really care about the Garrett producing a little less boost and might swap to the mitsu turbo later.
Thanks a lot guys
Jason
I doubt it. The saab green tops are just are 36# and the flash are almost 36# so I doubt it will run do to the difference ininjector constant not matching the blue tops.
So get the cobalt ss injectors. Can I run the Garrett on the gm supercharger reflash for the time being?
should be able to.
Im running the SS injectors and the reflash on my saab kit on 10psi.
Saab Kit, GM Reflash, 10 psi
