should be a 6203 bearing
the 6203 is used in every other GM idler out there accually i think they all use them
i have stock of them here even the INA newer style that are 14mm think insted of 12 which come in handy on 2.2 tensioners.
i can replace them if there metal plastic can't be replaced as bearings molded in as for the GM sc kit i have no clue why they would use a different pully, what size is it?? if its a 3" try a 3800 tensioner pully and see if it clears
JBO since July 30, 2001
http://www.wagneralt.com/catalog/books/W2008-02.pdf
There's the file for the replacement bearing on page 28 of the pdf file.
It's a Wagner part that should be available from Wagner.
Here's the Wagner part number: W02x-11
This should be the exact replacement by Wagner for the M45 supercharger pulley bearing.
Yeah I know old thread but receiving my idler assembly today for my M45 install next Spring prompted me to do some research on replacement parts for the setup.
Hope this helps.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
I am going to order this part as well.. however, I can not find a place to order it online. Has anyone had to order this yet? I actually have the OP's car now, and he has replaced it and its going bad again. So I am wanting to replace it and cannot find an NSK dealer around me, and Wagneralt.com doesnt have an online ordering system and the bearing is squealing. So is there a place to order a replacement bearing online?
