went through the boxes and install instructions last night with the pops. gots a couple questions?
intake manifold bolts. i can use the stock l61 manifold bolts correct? they are 6MM and the LSJ bolts are 8MM???????
Can I use the L61 alternators bolts to install the LSJ alternator? Called the local dealer, and he said they show the same part number, but the instructions say there are longer bolts???
Bolts that hold the blower to the manifold. do they HAVE to be the cap screw style, or will regular hexhead bolts allow a socket to fit in there?
thanks for the help in advance guys. blower goes on next weekend!!!
EvoFire wrote:went through the boxes and install instructions last night with the pops. gots a couple questions?
Go here:
http://www.mcmaster.com/#shoulder-screws/=bimosh. You want the M6 bolts with the 8mm diameter shoulder and 10mm long shoulder. You need 5 of them and i just used a regular set of m6 bolts for the 2 longer bolts.
I used the stock intake mani bolts for ~2 years until one broke off in the head this winter and forced me to heli-coil it. JUCNBST referred me to those shoulder bolts and so far i love them. Yes, you are correct with the L61 and LSJ bolt sizes.
EvoFire wrote:Can I use the L61 alternators bolts to install the LSJ alternator? Called the local dealer, and he said they show the same part number, but the instructions say there are longer bolts???
You need longer bolts, the stockers are too short because of the bracket you need to install.
EvoFire wrote:Bolts that hold the blower to the manifold. do they HAVE to be the cap screw style, or will regular hexhead bolts allow a socket to fit in there?
It is a tight fit with an allen wrench, i image that it would be a HUGE pita with regular sockets. I ordered these from Fastenal to replace my original bolts: M8-1.25 x 45mm CL 12.9 DIN 912 Zinc Socket Head Cap Screw
its an old concept. time for something new to take the reigns. - Z yaaaa
if you kit came w/ alternator bracket bolts, you can use those but otherwise stock will not work.
i bought 4 new bolts from lowe's for my supercharger to manifold install. the hex ends rounded on me.
this is the start of my signature: have you read the
RULES yet?
my carDomain updated 6/11/10 Forged and Supercharged
cool gues thanks. All the stuff I need is available locally for under a buck a bolt. just called to verify. Cooper State Bolt and Nut FTW!
Tinkle's beat to the Mcmaster carr....glad you found them.
Evofire-good luck with install. Post up if you have anymore questions.
one more question.
spark plugs. are the benefits to the colder ones one a stock m62 setup. will i notice anything drastic?
My car seemed to like the one step colder plugs better than the stockers. You are going to have to close the gap on the stock plugs atleast.
Im piecing together my superchargerkit....anyone have the specs on the bolts I need for the manifold to supercharger, intake manifold to block, throttle body to supercharger, alternator bracket bolts. I still need to get the tensioner and belt. Otherwise I have the blower , intake mani, ic pump, h.e, I.c. pump bracket, injectors. Anything else im forgetting
"It's called reading! Top to bottom, left to right... a group of words together is called a sentence. Take Tylenol for any headaches... Midol for any cramps."
manifold to supercharger - M8-1.25 x 45mm
intake manifold to block:
Tinkles wrote:
Go here: http://www.mcmaster.com/#shoulder-screws/=bimosh. You want the M6 bolts with the 8mm diameter shoulder and 10mm long shoulder. You need 5 of them and i just used a regular set of m6 bolts for the 2 longer bolts.
throttle body to supercharger - M6-1. The length depends on what TB adapter you are using and these bolts are included with my adapters.
alternator bracket bolts - Im pretty sure they are M6-1 and i dont remember the length. I'll check mine out and get back to you.
Thanks!
Compression Ignition Whore wrote:Im piecing together my superchargerkit....anyone have the specs on the bolts I need for the manifold to supercharger, intake manifold to block, throttle body to supercharger, alternator bracket bolts. I still need to get the tensioner and belt. Otherwise I have the blower , intake mani, ic pump, h.e, I.c. pump bracket, injectors. Anything else im forgetting
why are you gonna come into a thread and ask questions that have already been answered in said thread...MORON.
anyway thanks Tinkles and JUCN for the tips. I'm starting Thursday night with the tear down of everything, gonna clean up some bolts and things, paint the blower and start installing (and hopefully finish) Saturday. Would be awesome to go for a cruise Sunday!
sorry im in a pissy mood today...dont mind me..lol
Its ok dude...good luck with your build. Didn't mean to jack your thread. Just don't have any bolts coming with my parts im buying.
