Who can read cam specs?
What would be the difference in these two sets of cams.  (Explain it to me as if i knew nothing about cams)
Off the shelf, Comp Turbo cams
VS
The other is a custom grind by comp that I have bought...
INTAKE
Rated duration: 246°             At Valve Duration@.050"   204°   Duration@.200"  146°      Lobe lift .251   Valve lift .423
EXHAUST
Rated duration: 244°             At Valve Duration@.050"   200°   Duration@.200"  140°      Lobe lift .248   Valve lift .419
That's all the info I gots...
What kinda cams did I buy and will they work for a small 20G turbo...
Edited 2 time(s). Last edited Thursday, March 01, 2012 6:17 AM
Those look identical, Travis.  The only conceivable differences would be the centerlines and the ramp rates on the lobes, but I highly doubt those will differ much.
I have no signiture
I got a custom grind for a 16G and its works out fine!
They do look very similar.  Wonder why someone went with those instead of the off the shelf cams...
Either way, they are going into my motor...
Neither says anything about valve overlap. N/A you want overlap for scavenging, turbo you don't.
Personally I'd go with the proven Comp Cams
Would you still go with the proven comp cams if the custom grind was half the price (cause they are used) and still done by comp?
Perhaps I should call comp...
Edited 1 time(s). Last edited Thursday, March 01, 2012 7:13 AM
You could always put the cams in and measure them with a degree wheel and a dial indicator?  That will give you the centerlines/overlap.
I have no signiture
