So im trying to lean things out using supporting mods for the reflash. I was considering using a saab aluminum manifold with a ls1 tb. Now i have a chance to get a sheet metal intake mani on the cheap so im just wondering if anyone has tried a sheet metal intake with the reflash and what did it do for you
BuiltNBoosted wrote:Turn the boost up  that leans it out quick
exactly what I did, never had a problem when i was running the reflash
I did that, im running 14psi and still seeing low 11s... like 11.2-11.4 max. I wouldnt mind something more in the area of 11.8-12 max at a lower boost setting... say 10psi.
What are you running for a turbo? I did a upgraded my high pressure saab turbo and around 10psi it put everything inline
i just changed my name wrote:I did that, im running 14psi and still seeing low 11s... like 11.2-11.4 max. I wouldnt mind something more in the area of 11.8-12 max at a lower boost setting... say 10psi.
I would stick with where you are at... Thats pretty safe AFR for sure. I mean 11.7 would be really nice but 11.2 is quite safe.
