justa general question what is the diff between the safc and vafc a friend gave me a vafc but i dont know if it will work on our cars. ?   also with the adj pressure reg do you but just a reg one or a boost dep one ? with the reg one what psi do you set it at 50-60 psi ?
13's or blowning it. one way or the other!
VAFC = V-TEC SAFC, won't work on your car, well, at least the V-TEC stuff won't, but not sure if the other stuff will.
For the other question, you are mixing up AFPR's and FMU's. An AFPR is an adjustable fuel pressure regulator and is used for setting your idle and base fuel pressure. The FMU is what increases the fuel pressure above what the AFPR is set at during boost. I'm using both. The pressure that you set your AFPR at is dependant on what type and size fuel injectors you end up using.
