ok I searched and got many different places and different pn's for this thing..
2 questions
1: Where can I get the RIGHT full install kit of the walbro
2: is the walbro the same thing as the blazer pump (flow rate)
LE61T PTE6262 Powered
listening
Memeber since 4/2002
Premium since 1/2005
Garret t3 turbo charger for sale.. $75 plus shipping
jeep wrangler hard top for sale.. 97-up.. rear defroster and smoked glass..
$900 or best offer.. e-mail for more info
damnit someone answer this!
boost fourm ??????????????????
doesnt matter what forum I need an answer ASAP!
I have about 4 different answers I want calrification
I have edl-3581 from summit
autopaceperformance I dont know the part number for
theres a holley part number on summit as well but is much more expensive
and then the blazer.. does the blazer flow the same as the walbro?>
Walbro Pump
Pump number: GSS340M
http://www.autoperformanceengineering.com/
Both pumps are supposidly 255lph pumps.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
yeah but your asking a question that more of the boosted guys would know
or be able to help with
you been here long enough to know that QBE
now brian dont I need some sort of install kit with that
I didnt search in the boost forum, I figured it was more of a performance item then boost, sorry
Just giving you a hard time knuckle head
SpeedRacerZ wrote:Walbro Pump
still a little confused
the part number f2000169 or something, what is that for, that seems more like the right one
You use to be able to get it from High rev (if they are still around).
fpg003 aka gca758 click walbro on autoperformanceengineerig.com and it is the first one all the way to the right 108.00  all you need is the two wire harness plug and the flex hose under install parts.
<img src="http://img.photobucket.com/albums/v292/dragmyz24/shoppedcav2.jpg">
Rush Racing
http://www.gettherush.com/
walbro fuel pump install
Factory pump.  The plastic nipple is weak and I broke it.
Go to the hardware store and find a peice that is double in length and has the same diameter of the plastic nipple and put it in the new pump.  Or find someone with a lathe and go to work.
Here are the wire harnesses.
Splice and heat shrink
whats the PN on your pump?
god this is the 3rd or 4th install thread I have found on jbodies and ALL different
paco loco.
What is the part # for the Walbro pump that you are using?
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
-1996 2.4 liter + Turbo + Built motor + Torco + More boost = Lots o' Power
-2000 Mustang GT + 2004 Cobra motor, Whipple 2.3 supercharger,
built rear-end,Dodge Viper spec T56 6 speed, bolt-ons = wheelies at the track!!!!!
fuel pump info
the GSS340M was discontinued and replaced with F20000169.  So the second part number is the one you want to look for/order.
i just received confirmation that the application fpg003 is what we need and a flex hose piece
