Which wideband unit should I go with. Either the LM1, the PLX 300, or which ever. I need some input . Whether it be about data logging, or functionality, which one works best????  Get the idea?   I need some of that deciding info. I can't make up my mind one which one I should get.  Thanks.
T04B V-trim baby.....Time to Open a Can of Whoop A S S !!!
I have the LM1 and i am very happy with it, i have yet to use the data logging.
  -  93 mph in the 1/8 mile
Member of J-Body Of Michigan.
What about the Zeitronix Zt-2 unit? Do you have any comments about it?
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
Diesell wrote:Which wideband unit should I go with. Either the LM1, the PLX 300, or which ever. I need some input . Whether it be about data logging, or functionality, which one works best????  Get the idea?   I need some of that deciding info. I can't make up my mind one which one I should get.  Thanks.
The plx 300 only gives you a readout and 2 analog outputs-0 to 1v and 0 to 5v. It has no possible PC communications. Cost about $330.
The plx 400 gives you (internal) logging and PC connectivity. Logs 4- 0 to 5V channels at 10hz for 1 hour. same to analog outputs as the 300... 0 to 1v and 0 to 5v. $470
The Innovate LM1 gives you a readout, (internal) logging of A/F ratio for 44minutes at 12hz, and 2 fully scalable analog outputs. Unit has PC connectivity and analog outs are programmed via PC. $349    also available with an expansion box that allows logging 5 more channels (1- frequency, 4 0 to 5v) at the same 12hz for 44 minutes --- $429.
Innovate also the LC1 controller. It has no display or logging. It has 2 scalable outputs and full PC connectivity. $199
Both the LM1 or the LC1 can be connected to the XD1 readout, which is a 2" gauge face that can control either unit. Price varies if part of a kit. Unit alone (not in any kit ) is $99.
The Zeitronix Zt-2 offers a Controller with PC connectivity, EGT input, and up to 5 other inputs (using their sensors). No readout. And 2 non-adjustable outputs (0 to 1v narrowband, 0 to 3.5v wideband). Datalogging is done (external) via a PC with proper software and can be up to 74hz. $279
There is an upgrade kit for the Zeitronix Zt-2 that adds a display for $399.
DynoJet has a kit that has RPM and TPS inputs, can log data (internal) for 10 minutes at 10hz, has a relay control output, has a 2" display, and has full PC connectivity. around $499
SIde note: The LM1 is now a standard option when purchasing a Mustang Dyno.
sig not found
The LM-1 is a nice unit but yes their Standalone unit is superb!
Hmmmm....soo many to choose from.  I think I may be leaning towards the Lm-1 with the 2" gauge and datalogger....I'm not sure.   Still need some really decisive info. to make my choice.    Thank a lot guys!!!!!    By the way Todd, how's it going with 2.3L bin file ?????
opinions:
PLX devices cost too much for what you actually get.
Dynojet is a complete package with no options to buy, but you pay for more than you generally need and pay for the name. Relay output is nice though...especially for use with nitrous.
Innovative's is a good package, whichever package you choose. adjustable analog outputs have many more uses than are easily seen. An output set to 5v at 12.8:1 and 0v at 13:1 can easily operate a small Radioshack 5v relay and accomplish almost the same thing as the Dynojet output. Except it can't be triggered by 3 things at once (TPS, RPM and AF) as the Dynojet unit can. Karo's prices on the Innovate products are much better than the list prices I put in above.
The Zeitronix stuff seems like a good deal, although the base unit's capabilities are mildly disappointing. The price for the options seems very high to me. An Innovate LC1 does everything the base Z2 does for about $100 less.
No, I havent had any luck with the bin file. I've been really busy with other things and havent spent much time with it.
sig not found
go for Innovative's Stand alone its awesome setup its just like the lm1 without the bulky stuff, comes with this great guage that is very thin and can be mounted anywhere
i beleave they sell for like $399 you cant beat that... to bad you didnt get in on the GP that just went threw
good luck
ive got the lm1 and have been happy with it
and ive got the stand alone gauge coming from karo
personally , the difference in prices and the bells-n-whistles are all optional , as long as you can see the gauge while testing , racing , dynoing , the data logging to me is a option thing not always needed , but it is nice to free you up from other duties
And the AEM UEGO, what opinions do you have?
Thanks for the info. guys, still deciding which one.  Todd,  thanks for the info. That makes things a little clearer.  By the way, I just picked up a 2.3L from a 93 olds achieva with the 5 speed for a $100.00. Only problem is that the head has a crack.  No big deal.     Time for the BUILD.
