i just have a quick short question. I had got my turbo a long time ago from precision. the intake a/r is .60 and the exhaust is .48. i have an ecotec and plan to run 300hp or less. is this turbo to big?
if its a t3 super 60 (which is what it sounds like) that size will work very well for your plans of 300hp or less. its probably one of the best sizes you can get for decent power gains.
_________________________________________
450WHP Turbo Ecotec swap in the works...
Shifted, i dont see how you only spent 2800 so far. I spent 800 just on the turbo. And at least another 2000 to date. I still have to buy 2000 more in parts! this custom setup is looking to never end lol.
It pretty hard to say if the turbo is the right size if you don't know exactly what you have. It could be a 50, 57, 60 trim ect.  You need to take measure the compressor wheel to know for sure.  It is most likely a little too big got you 300hp or less needs but without knowing the exact size i can't say if it is close or way off.
  -  93 mph in the 1/8 mile
Member of J-Body Of Michigan.
I certainly didn't spend $800 on the turbo
2.3 HO Intake Manifold - $65
T3 Turbo Exhaust Manifold - $200
T3 .48/.50 60 Trim Turbo - $150 (Just a guess, I traded stuff for it)
30x6x3 Johnny Racecar Intercooler - $185
TurboXS RFL Blow Off Valve - $75
2.5" Downpipe - $10
A'Pexi SAFC-2 Version 2 (Black) - $270
30lb/hr Ford Red Top Injectors $100
Cartech BEGI 2025 Adjustable FMU - $180
Accel Adjustable FPR 74565 - $105
Autometer Ultralite Boost Gauge - $50
Autometer Ultralite A/F Gauge - $50
Autometer SportComp Fuel 1.5" Pressure Gauge - $40
Mandrel Bent Charge Piping - $90 + $35 = $125
1/4" ID Braided SS Oil Feed - $50
5/8" ID Oil Return - $25
Mushroom Foam Air Filter - $25
Felpro Intake Gasket - $40
Felpro Exhaust Gasket - $25
Felpro Oil Pan Gasket - $25
Enough brass fittings to plumb a house - $15
2.5" Single in - dual out muffler - $100
2.5" High flow cat - $65
2.5" Flex pipe $40
Silicone hose connectors - $160 (With clamps)
T-Bolt Clamps (Above)
Steel T3 Gaskets - $25
Grade 9 Turbo studs and nuts - $15
So total: $2215.... lol, guess I'm doin better than I guessed
t3  .48/ .60   I got it from a shop that i go to. they had just boosted a sunfire and said that it worked great. So i told them to buy me one. I like how much you have spent shifted. My price list is somewhat more.
Turbo w/ all flanges and gaskets- 800
wastegate from turbosmart- 260
twostage boost controller from turbosmart- 200
stage 2 axles for automatic- 300
autometer phantom boost gauge- 60
autometer phantom egt gauge- 100
innovate standalone a/f gauge kit- 340
most stainless intercooler pipes- 220
tranny cooler- 40
custom gauge setup in dash- 100
AEM intake- 40
all together about 2460 and i know im forgetting something. I know i need more parts, ill list what i think i need, if you can see anything i missed, please add.
intercooler from ebay (spearco) 250
exhaust manifold from eX- 300
Fuel pump- 100
rc Injectors 440cc- 400
safc II - 240
fmu- 70
fuel press gauge- 100
exhaust cutout- 150
turbosmart bov- 120
vac lines, oli lines, small things- 100
thats about 1800 in parts that i STILL NEED! thats about 4290 in my turbo kit. I started this only wanting to spend 2500 like most people said and i just wanted the best stuff and each part had to cost me. If you have a good idea to cut the price without cutting the quality of the parts. back to the topic that i started out with, the guy at the shop said the turbo can hold 20psi and 450-500hp. thanks for your help!
<br>
<img src="http://home.nycap.rr.com/xenox/jbody/jbody_shocker.jpg">
i bought my turbo off ebay used for $80.00 then bought a rebuilt kit for $100.00 and did it myself...if you can find a good turbo on ebay thats used out of a existing car..then you could save yourself some cash $$$$
Shoot... I've spent way less than even shifted did.
2.3 High Ouptut motor
Custom built turbo: .68 a/r P trim turbine wheel, T4 turbine inlet/3" v-band out,  T04 compressor, .70 a/r 60 trim compressor wheel
Saab intercooler
2.25" charge pipes/couplers
3" straight through v-band clamped exhaust
turbo XS type RFL blow-off valve
38 mm Stone Mountain wastegate
Custom Intake manifold with four injectoer bosses welded in
eight 35lb injectors
two fuel rails
Greddy Rebic III AIC
Greddy Rebic III simulator
In-line 95 PSI max Master fuel pump
Accel LS6 AFPR
Braided fuel/vaccuum lines
MSD programmable DIS-2
3 bar map sensor
New GP sorenson external coils
Modified 2.2ohv ignition module housing with 2.4 computer
Accel 300+ 8.8mm wires
NGK TR6 plugs
Autometer boost, egt, 2x oil pressure, a/f and fuel pressure gauges
HKS mushroom filter
3" short intake off turbo
Port and polished H/O cylinder head
New Bosch O2 sensor
New MAP sensor w/ check valve
There is more.. I just can't think of it.... registry is not up to date....
Cardomain|
Myspace
My figures cam out a litte different:
 2800
-2200
   600
That's like 200 trips to Taco Bell....
Cardomain|
Myspace
T3 .48 a/r exhaust, 60 trim compressor - $600 CDN
Turbo Manifold, BOV - freebie
3/8" stainless braided oil feed line - free
Oil Pressure Regulator and Fittings - $12 CDN
MSD Inline - $60 USD (roughly $80CDN)
Vortech/BEGI Adj. FMU - $250CDN
Eagle Rods - $400 CDN
Johnny Race Car 6" FMIC - $300CDN
Wiseco 8:1 +.020" overbore pistons - $550 CDN
2.5" custom header wrapped downpipe - $90 CDN
7 -AC Delco Oversized oil filters - free
brand new water pump - free
Spec Stage 3 Clutch - $450 CDN
New OEM Camshaft - $130 CDN
2.5" Mandrel Bent Aluminized Piping - $100 CDN
Comp Cams 1.6:1 Roller Rockers - $140CDN
Donor Engine - $400
Autometer Phantom Oil Pressure Gauge - $80 CDN
Autometer Phantom Boost Gauge - $70 CDN
Autometer Phantom A/F Gauge - $40 CDN
Izusu Impulse Diff. Gears (whole tranny) - $50 CDN
Port and Polish, 3 Angle Valve Grind - $210 CDN
Stainless Steel t3 Flange Gasket - $25 CDN
Various AN Fittings, Brass Fittings, Pipe Fittings, etc - Free
total so far:  $3977 CDN And I'm not even boosted yet
haven't bought headstuds/bolts, flywheel bolts, clutch bolts, bottom end gasket kit, vacuum line, cam bearings, oil pump, or gotten my block machined yet.
wow
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/toond.jpg"></a>
ah crap, I forgot my wideband.. another $100 CDN shared between 2 other ppl.
Shifted why did you buy a AFPR and a cartech FMU?
i guess i should move to the U.S
Garrett T04e $600
28 x 7.75 x 3.5 intercooler off e-bay $290
Greddy type s blow off valve $200
Turbosmart wastegate $447
apexi turbo timer $150
msd dis 2 $400
= $2087 Canadian
and i still got to buy my piston and rods
