Hey guys,
well, i think my seller might not be able to come through. Does anybody else have a gm s/c map sensor for sale?  GM pn 09350899.   Or does anybody know where to buy one other then gm
thanks.
Nate
1995 Cavalier W/2k1 Engine
Nate, is there a reason you NEED the 2-bar for the S/C?  I picked up a 2-bar from some GM for $30.  It has the same 3 wires (blue, orange, and white), but a different connector.  For the money, I can do some splicing.
Drop me an email if you'd like.  I can probably dig up the company I bought mine from.
Matt S.
<a href="http://www.cardomain.com/id/kindofcavy"><img src="http://img61.exs.cx/img61/8537/J-Sig8b.jpg" alt="Image Hosted by ImageShack.us" /> </a>
Built not bought, check that!
I need the GM s/c map sensor b/c from what i Understood from Brian/speedracer's post  on 2 bar map sensors, is that its the only one that works with the reflashed pcm.
Nate
any 2 bar map that reads from 1-5volts will work just fine with the reflash, im using a msd 2 bar map it just uses a different plug but it works fine... im using  MSD-2312 and only costs about $50 canadian, and the plug off a older 2.2 cavalier works on it, just go to a wrecker and grab one
Derek Z24 wrote:any 2 bar map that reads from 1-5volts will work just fine with the reflash, im using a msd 2 bar map it just uses a different plug but it works fine... im using  MSD-2312 and only costs about $50 canadian, and the plug off a older 2.2 cavalier works on it, just go to a wrecker and grab one
So that works with the reflash eh. From reading
http://www.j-body.org/forums/read.php?f=40&i=50071&t=50071
I thought other map sensors wouldn't work. Did u just get yours from any parts store for that price?
Nate
I sold my gm s/c map sensor for 30$ shipped.  then found out it was like 120$ from GM. ahh well. i knew the guy pretty well.
good luck
brian..where are u??
Nate
yup thats the one im using, and its been working just fine for me
