Will a clutch from a 99 Z24 (2.4) fit on a 2001 Z24(2.4)???   I was wondering b/c I need a clutch and if this one will fit, I won't have to order one...  I can pick one up in town...
Thanks Ahead of Time
"Why Are We Dying To Live, When We're Just Living To Die"
If you use a clutch kit from a 99 then you also ned the flywheel.
Mark P.
yup, cant mix and match clutches and flywheels.   They both have to be from the same year.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Are the number of splines on the shaft the same on both transmissions?
O noes!
I have no idea about the number of splines....   Thank You all for your help.....
i got one for a 00+ z
i sell it for 200 shipped
it is a centerforce
got some parts for sale.  Hit me up
# of splines is the same, but 99 has the stepped flywheel I believe.
95-99 isuzu trannies have the stepped flywheel whereas the getrag is more of a flat looking flywheel.
# Splines is the same between both trannies.
-da chinchilla
As far as i know you can use 99 on 2000 two different styles. I may be wrong.
99 was the isuzu tranny
2000 was Getrag tranny
 all the time
flywheel and clutch are interchangeable between the isuzu and getrag only as a unit.  You can use an isuzu flywheel and clutch on a getrag and vise versa.  HOWEVER you cannot use a getrag flywheel with an isuzu clutch, and vise versa.
-da chinchilla
This is true.  I am using a getrag flywheel and clutch setup in my 99 with now problems
Jason
99 Z24
#25 to register on the Org !!
www.newdawncustoms.com
Johnny Mack Turbo Systems
Engineered Performance
aside from the problem that your differential is in pieces and you cannot drive it
-da chinchilla
Yeah, that is a bummer
Check your mail
Jason
99 Z24
ooooohhhh.
Soon I suppose then huh?
-da chinchilla
