How do i add transmission fluid to my 95 2.2 auto 3 speed? i think its slow and i dunno how to...
SPONSORED BY: CAVALIER EXTREME
If there is no dip stick you probally just dont have to add fluid,unless you get the fluid and filter changed...its a sealed for life tranny.  Other than that if there is a dipstick you just add fluid there.  Make sure you have your engine warmed up and running in park when you check your fluid level.  If it is low (below the bottom dot) than with a funnel add a liter(quart) ...i'm canadian...if that brings the level up your done...if not add another liter untill the level is between the 2 dots on the stick...that is the opperating area.  DO NOT ADD FLUID IF THE CAR IS NOT AT OPERATING TEMP AND RUNNING FIRST.  As a side note i have used lucas transmission fix fluid.  It was great.  My old calais had slippage and that stuff fixed it.
Cheers
