Has anyone here just cit and rewelded there stock shifter? If so to what sucess?
That would just change the length of the actual shifter, not change the throw
The handle and shifter are different parts.
go on V6Z24 they did it (well jason the site owner) and its a real short throw shifter!
Slammed Ohv wrote:That would just change the length of the actual shifter, not change the throw
Shortening the length does shorten the throw
Think of it like a pendulum on a clock. It takes longer to reach the side at the bottom of it than at the middle. Although its not a 'true' short throw shifter it does shorten throws.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Shortening the length of the shaft above the pivot does not change the length of the throw (no matter how many people say it does). It does, however, change the distance that your hand moves (less). I built one for my car, since there isn't one available-
here it is. The best place to change the distance of the throws is on the transmission end. By shortening the arms where the cables attach, you can drastically reduce throws.
I was going more for looks anyway.
ok, i compared the length of the b&m shifter and my stock one when i installed my new shifter and the lenght after the pivot ball is exactly the same......so taking a hacksaw to your stocker is exactly the same as the B&M shifter.....i wish i didn't throw away the 130 bucks for the same thing as a cut stock shifter........oh well, at least it looks cool
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
ok, but then if you hacksaw your b&m it would shorter the throw over on top of under the pivot ball !!! so its like..x2!!! isn't it?
you need to lengthen the bottom part, under the ball...... cut 2" from the top half, and weld 1" onto the bottom half.......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
but i never saw a difference between my b&m and my stock shifter after the pivot......mabey i need an eye exam, or mabey memory is a bitch because it has been over a year, but i could have sworn that they are the same after the ball
and i though about cutting my b&m shifter, but then i'd have to rethread it for the knob and stuff
if i get around to it i'll go to the junkyard and grab a shifter and compare it
Hail Satan
I think the B&M is clearly slightly longer under the ball here.
i had my stock shifter cut very short.........your hand moves less, but engaging the gears is the same........The B&M is a short shifter and DOES shorten up the @!#$ing..... ALOT.... it also stiffens up the assembly so that its not so sloppy........worth every cent i payed for it.....
Wild Weasel wrote:I think the B&M is clearly slightly longer under the ball here.
yep, your right, im wrong.........hmm, i could have sworn they looked the same, oh well
either way, if you don't want to spend the cash, cutting your stock shifter isn't a bad idea
but the b&m is better
Hail Satan
Brent Lawson wrote:Has anyone here just cit and rewelded there stock shifter? If so to what sucess?
just to clarify for you guys that cant read
he says cut and reweld meaning.......cuts some off the handle and then cut some off the bottom then were you cut the stuff of the bottom weld in the stuff you cut off from the top then weld the bottom back on
thus creating a real short throw shifter
well if he did that im sure it would work just as good as any other short shifter
Hail Satan
