im having problems with my tranny... sometimes it grinds when shifting from gear to gear. and it getting kinda hard to shift... im not sure wether its the shifter, the clutch, or the tranny.. i hope to god its not the transmission... can anyone help... or suggest things i should try to narrow the problem down even more...
JBO'S Mr. 64.....
anyone?
<a href="http://clk.atdmt.com/TRU/go/skmnmtru0010001035tru/direct/01/" target="_blank"><img border="0" src="http://view.atdmt.com/TRU/view/skmnmtru0010001035tru/direct/01/" /></a>
1) Give some time for people to respond.
2) Check your clutch fluid, how much you have? None?
yeah check that definately...
does it grind when the vehicle is in motion/stopped/both?
try driving down the road very slowly and push the clutch all the way to the floor for a second or even 2, then try to shift... does it grind then?
could be synchros... could be your clutch not fully disengaging from the flywheel...
