has anyone changed the gear ratio's in a 4spd? (4T40E)
if it has been done, where can i get the gears from?
Kardain wrote:Tonite on Fox:
When X's attack
If you want new gears, find a transmission shop that carries
TranStar Industries. The catalog listed doesn't tell you what the ratios are though. You can also look up the RPOs for the 4T40E for the different ratios and get the differential from a salvage yard.
How in the hell do you view the catalog after it is downloaded.
am I being dumb here?
You need Adobe Reader, it'll down load as a PDF file.
Oh I just renamed it with a .pdf on the end. Thanks
Could you design a different combo torque converter.
Clicky
I wonder if you could you use a 4T65E converter in a J-body. I mean it is physically the same size right! And it is built better.
