are the cavy 02+ with eco's the same at the 2.2 cobalts af far as trannys?
yes...same motors and same trannys
IIRC someone said that the cobalt trans is different from the eco j trannys
Now Powered By TEAM GREEN
boost will be soon for me....
thanks to mil county police in the state of wisconsin. I know that my window tint is rated at 3.7%
Z Speed Cavi wrote:IIRC someone said that the cobalt trans is different from the eco j trannys
I was thinking that was just with the 2.0 S/C
I may be wrong.
I can't be sure, but internally they are the same, if anything is different it is the tranny mounting points on the case.
And the 2.0SC tranny is completely different. ONLY the diffs are interchangeable between the 2.
As I posted on the CSS.net site where you posted this....
The 2.2L's share the same F23 transmission. Identical transmissions.
The 2.0L has a F35 transmission. Completely different transmissions.
You can change the differentials between the 2 but that's it.
You can change the ring gears between the Cavs, Fires, Cobalts, HHR, and a couple others for nice combinations to suit your needs.
5K PB: 24:50
10K PB: 54:26
