I got a Q..
I almost got the car back together, but can't find a clutch and pressure plate. I figure I'll buy a new one but replacement stuff is too damn much for what you get. I saw I can get a stage 1 Spec for cheaper and it comes with more stuff. My Q is can I use the throw out that comes with the kit on my new venture? keep in mind I have a 2.4 Flywheel. Do I have to order it for the HO with the New Venture? Will I have to get a HO flywheel? I though the flywheels were a direct swap.. but just wanna be sure.
anyway, can I get some help guy?
The TOB goes with the tranny, not the flywheel. The TOB is made for the forks in the bell housing.
So as long as you have a TOB that work with the forks and is big/small enough for the pressure plate springs, you're good to go.
Gilles
2.3 Ho
just make sure you get the clutch that matches the flywheel
ty for the insight guys! I'll let you know if it works with the New Venture.
Mfk-223 wrote:The TOB goes with the tranny, not the flywheel. The TOB is made for the forks in the bell housing.
Only the External slave trany's have the Fork........ the ones we use for the swap are the 93/94 Internal slaves...... no fork
You can use the 00+ Getrag Flywheel on the NVG..... same flat style flywheel......
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
cool ty for the info
