i got my autotrans interceptor today. does anyone know if they turn ets off? because my ets off light is now on.
also when i put it into drive its a pretty loud clunk...should i turn it down or is that ok and normal? i think its up about %50
FOR SALE: (5) '95-'99 Z24 Rims
It's normal for the ets to go off depending on the year of your car.
On the clunking, do you have engine mounts??
If not and you still have the original mounts, will cause it to clunk because of the harder line pressure making the tranny shift harder.
If the engine mounts haven't been changed, you better do so with this shift kit. If not, you'll stand the chance of hurting the factory engine mounts even more causing more problems in the drivetrain too.
I've had my autotransinterceptor for about 5 years now set at 75 percent. No problems and still works great to this day.
Good luck with it. Once you do get used to it's benefits, you'll never go back to stock.
Misnblu
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
upper and lower mounts? what ones do you reccomend?
atleast get a lower mount, I would start there since they are so cheap.
yeah im gonna get a package with both of them. thanks.
If you want to avoid the clunk, rev up to about 1200RPM before you go into drive.
Until you can get the mounts, that is.
um...NO do not do that!...that will destroy your tranny...why on god's green earth would you suggest that to someone?
Neutral drop > 4t40e auto tranny
It's not really a neutral drop. 1200 is only like 300 RPM above idle. I've been doing it forever.
It's still not recommended if you want to keep the tranny in good condition over the years.
Longevity is the key here.
Misnblu
Misnblu.com
1200rpm is 600rpm higher than what an auto should idle. No it's not recommended.
Gilles
2.3 Ho
ok thanks, i wont do the reving thing. ill just get motor mounts and the auto trans mount when TTR comes out with it here soon.
Sorry, my Quad4 idles at 900RPM, and when I shift like I do, it feels like I'm shifting into drive WITHOUT the line pressure turned up.
I'm guessing from the responses that it's not that great an idea, but I'll keep doing it and I'll take note of when the tranny explodes
eh idk what you guys are talking about....YOU CANT neutral drop our cars... if you try the motor just bogs out and it doesnt work. at least thats the way it is in my 98 z24.
White 98'Z-alive n kickn
Black 97'Z-down for the count
