does any one know where the drain and fill pugs are on a 98 cav m/t 2.2ohv
well, if you look at the bottom of the treans from behind the front rotor (i reccomend taking off the tire) you realy cant miss the drain plug. as fot filling, once you have said wheel off, you'll see a little thing above the plug what looks like a lever. if yours has anywhere near 100k mi. on it, it might not be white anymore, but thats what color its supposed to be. if you can, BEFORE lifting that latch blow the direct area off w/ shop air so you dont get any dirt in your trans. then lift and remove the plug, clean it off, and refill wit the car on a completely level surface. make sure to have at least three quarts of synchromesh on hand. to fill, i find the easiest way is to run a clean piece of 3/8 fuel line down from the top of the engine compartment, one end in the fill hole, and place the tip of the bottle in the other end, and fill away.
thanks a lot i've been trying to find out that for the longest time
hey i found the drain plug but i couldn't find the fill plug. i didn't see any lever of any kind except the shift linkage.
to add on to that... here's a pic... its on the firewall side of the tranny
- Attachments
- Jul17^82.JPG (94k)
dude your a life saver thnanks so much, if you lived in pittsburgh i'd buy you a beer or 3
