Where is the fill for the trans fluid on a 96 cav with a 2.2 5spd? is it in the same spot as the 4t40e?
under the car beside the wheel well there should be a plug
Displacement= 2.2L
Valve Train= OHV
Bore & Stroke= 3.50 x 3.46
Compression Ratio= 9 to 1
Net HP @ RPM= 125 @ 5200
Maximum Torque Ft Lbs @ RPM= 135 @ 4000
Fuel System= MFI
Normal Oil Pressure: psi @ 3000 RPM= 56
driver's side wheel well there will be able to see a white lever. you will have to get under the car to see it, make sure you have enough light. once you're under there you will see the drain plug on the bottom of the trans. remove this plug to drain the fluid.then clean and replace this plug. clean off the area surrounding the white handled fill plug lever before removing the plug, which is done by lifting the white lever. pull straight up to completely remove the plug. clean the plug to make sure you don't get any road grime into your trans. make sure the car is on LEVEL GROUND to add the fluid, use only synchromesh. the best way to do this is to get yourself a new length of 3/8" fuel hose, drop it in from the top of the engine to about where the fill hole is, then get back under to make sure the hose goes in the hole. once back up top, your synchromesh should have a little pour spout top on it. cut the end of the top off, stick it in the hose, and fill away. after two quarts of synchromesh, go back under the car and check the level with the plug. if you need more, add it. if not, put the plug back and drive away.
Edited 2 time(s). Last edited Saturday, February 10, 2007 8:23 AM
Rich must have read that straight from GM
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
SpeedRacerZ wrote:Rich must have read that straight from GM
experience doing it twice. yay for doing your own maintenance. its so easy with cavaliers, everyone should do it.
