What would you reccomend for use in a Getrag ? 5w30 ? Trickshift ? Saturn Man Tranny fluid ? What would get the job done best ?
My Cav
I give up...
Mobil 1 or Royal Purple ATF. Basically any GOOD, NAME BRAND SYNTHETIC ATF.
5K PB: 24:50
10K PB: 54:26
Really ? ATF in a getrag works just fine ?
My Cav
I give up...
That's what it calls for. It's not that uncommon.
5K PB: 24:50
10K PB: 54:26
I use Royal purple syncromax. No problems here.
Ok what is the best fluid to use on the older Getrag?
<a href = 'http://ivpnewmedia.com/10thst/tifts/'>
<img src = 'http://ivpnewmedia.com/10thst/tifts/dpBanner.gif'></a>
the getrag 282/ nv550 uses gm syncromesh. ive heard of people using other fluids with mixed results. i personaly use syncromesh and a tube of moly slip manual trans additive and it works great
I use Royal Purple Synchromax in my NVG T-550, personally. Works great.
-Chris-
-Sweetness-
-Turbocharged-
Thanks to everyone for the answers !
My Cav
I give up...
Just FYI, my 1988 HM282 called for 10W30 instead of synchromesh. Had zero issues using Mobil 10W30.
Mobil 1 since I have owned it. It's a little stiff shifting in the really cold temps(10deg F or lowwer) but its smooth as silk once everything warms up.
I also used redline atf and I had no complaints....never got to use it in the winter though. my first trans took a dump and I've used Mobil ever since.
so do I use motor oil in my hm282 or Synchromax bc my hm282 is out of a 89 cavalier.
i would use versa-trak fluid from gm (used in newer awd diffs and t-cases)
I used Wal-Mart synthetic ATF in mine... I never once heard this mysterious "getrag growl" that apparently the 00+ Getrags commonly have...
Redline equivalent to synchromesh for me.
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
Bringing back a dead thread...
Just want to confirm how MUCH fluid to put in as well?
I've heard
ABOUT 2L but I want to know exactly how much and not too much
Buddy Club Ecotec Cavalier
* More to come *
Stock is 1.8 Quarts.
GM released a service announcement for 00-02 Getrag stating that if you are experiencing noise/humming, that over filling to 2.6 Quarts is recommended.
So anything between 1.8 and 2.6 should be fine.
I am running 2 qts of B&M Think Shift and no problems here.
I put 2qts of B&M Trick Shift in mine when I did the swap but its a little noisy, probably wouldn't hurt to add a little over the recommended to make sure its quiet.
Ive read on here that someone dumped 3qts in and hasn't had any known issues.
