just like the subject says, im lookin for the thread on the pre getrag ld9 5 spd tranny swap to the 2000+ getrag but am an idiot and cant seem to find it can someone post it for me that would be awesome
"sometimes the respect is more important..."
ok...i dont know if you know this or not..but if you have a 95-99 5speed isuzu then it is MUCH easier to swap in a 92-94 getrag than cutting and welding new mounts for the 2k+getrag ..and the outcome is about the same if not better
well thats good is there a good write-up bout that swap anywhere?
does anyone know where i can get the 92-94 getrag anywhere i need a tranny bad
I know a guy who sells this New Venture Gear T-550 with 3.94 final drive ratio (brand new transmission) for only $749.00 USD! nobody can find this deal anywhere. I think He has five more left. any of you who were lookin for one.. should ACT fast! price was 2,800 usd for a brand new. $749.00 deal is bomb!
This transmission is a special EUROPEAN EXPORT-ONLY unit and has a special race-bred gearset not sold in the US! The assembly code is 4DFF and carries part number 10235022. The gear ratios are lower than all the V-6 Getrags and most other Quad 4 Getrags. This is the ultimate drag racing or road racing gearbox. It can also be used as a stock replacement for any Quad 4 car.
pm me (colemanz24@gmail.com)
Check Ebay for the NVG trans....
I like the F23 Getrag better myself, and the NVG is harder to get parts for.
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
i'm in a similar boat.. Brian you comented a couple times in my last thread. is there anything else other then mounts that needs to go with the tranny? i'm swapping in a LD9 from a 2.2ohv. so i need to makes all the mounts and everything. so is it just the mounts for the tranny i'll need to worry about, and averything else just bolts right up?
If going from the Isuzu to the F23 Getrag, you'll need the shifter, cables, hydrolic lines for the clutch, and the GM rear trans bracket (gets welded in).
If going from the Isuzu to the NVG transmission (older Getrag style), you'll need the front (I believe its the front) trans mount from the donor car, and a custom 'cable extension/adapter' for one of the shift cables...... also a throw out bearing/slave cylinder for the NVG (you can use the older Quad 4 flywheel, or Isuzu flywheel, + matching clutch assembly)
I believe that about covers it.....
SPD RCR Z -
'02 Z24  420whp
SLO GOAT  -
'04 GTO 305whp
W41 BOI -
