so my slave cylinder is going bad (leaking)  the car just broke 60K miles.   it's not a performance build by any means, anyway i was thinking while i'm in there should i change out the clutch and have the flywheel cut or just the slave cylinder ?   I think the clutch still has a good amount of life to it.  Anyway  what's your opinion?
Don't you bottom out?
- Yes I do
Well not a bad time to do it. Even if you got like a stage 1 clutch.
if you're there, do it. also, i got my oem flywheel (2.2) for $40, brand new. last i checked, turning a flywheel cost roughly $30... may as well use new parts.
I just had the same dilemma. I went ahead and replaced the clutch, but only because I thought it needed a new one and I already ordered it. I think it depends how many miles are on your car and how you drive. I had about 75k miles on mine.
I think with 60k miles... you could go either way. You probably have alot left on the stock clutch. Plus if you don't care about performance then i would say just replace the slave, because a new clutch will run about $500.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
ECOTEC wrote:I just had the same dilemma. I went ahead and replaced the clutch, but only because I thought it needed a new one and I already ordered it. I think it depends how many miles are on your car and how you drive. I had about 75k miles on mine.
Huh?? A stage 1 clutch (Spec ) is $346.86. This comes with a TOB/Slave. The TOB/Salve by it's self is $174.
oh. Well it would still be cheaper to just replace what's broke (slave).
Besides... Stage 1 spec Clutch=$350
Shipping will be ATLEAST........$25
Getting the flywheel turned $30....Or more if your getting a new one.
So it would still be over 400 dollars... After everything was said and done installing my Stage 2+ it was over $500.
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
yep  i think i'm gonna just buy a new flywheel  and get a spec stage 2+ clutch   i need to rid my car of this problem soon
- Yes I do
Are you getting a new stock flywheel or an aftermarket one?
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
that's one of the things i haven't decided yet
- Yes I do
