need a lil help here guys lastnight i broke something in mt driveline either my clutch or  in my tranny but the car will not move it was as if it poped out of gear then stoped while i was taking off from a paring lot.. not i wasnt trying to smoke my tires!!!!! i did notive that i can run through the gears w/o the cluthc and the vss (vehicle speed sensor) was making my speedo move im not hearing and grinding through the tranny now but then again i cant realy get under it........ can any one send me an expliated schematic of the getrag 2000 2002 incase in need to look at the syncros
THERE CAN BE ONLY ONE, i have already died once and im still here so lets just leave it on the track
check your axle bro. i would have to look at it to figure out the issue. you checked the @!#$ cables correct? also do you feel any preasure on your clutch. throw out bearing could be stuck full out. where is it now? If you want this weekend i can come take a look? sunday maybe.
NightmaresCavy wrote:check your axle bro. i would have to look at it to figure out the issue. you checked the @!#$ cables correct? also do you feel any preasure on your clutch. throw out bearing could be stuck full out. where is it now? If you want this weekend i can come take a look? sunday maybe.
clutch feels normal cables are attached and when you put it in gear the speedometer goes up like its getting a reading from the vss i almost think it may be the outputshaft
that is possible. to much wheel hop.
 just wish it was a month ago then you could have bought my getrag and i would have helped you put it in.
well i found out what went in my tranny as soon as i got the drivers seide halfshaft out the diff fell to the bottom of the case and the passenger halfshaft was a muther %$cker to get out
ill take some pics tomorrow and post them
dont take this the wrong way, but someone needs to learn how to drive, if you went through 5 now........
Chris
'02 Z-24 Supercharged
13.7 @102.45 MPH  Third Place, 2007 GMSC Bash  SOLD AS OF 01MAR08
Taetsch Z-24 wrote:dont take this the wrong way, but someone needs to learn how to drive, if you went through 5 now........
Chris
ummmm village idiot i have gone through 5 trannys only one
