I'm looking for a getrag tranny that came in J-bodies with 2.4 motors (right before GM swapped to the eco)
and I just want to make sure that I have the years right....
I believe that they came that in in only 2000 and 2001.... am I right or wrong?
^^^ Thanks... I'll just tell the salvage yards I have a 2001 then just to make things easier.
There is something esle I want to make sure of too....
I have a 97 with an Izuzu, and I'm swapping to a getrag. Since I have a 2.4, the getrag should just bolt right in without modification to any mounts right? I know there is a list of other things that need to be replaced... I just want to be damn sure that once I have a getrag compliant clutch and pressure plate on the engine that it will just bolt right in.
Once the tranny is in and the car is on the ground.... I can start replacing all the other crap.
I knew about everything except the mounts.
So you have to cut and weld like with  the 2.2 then hugh.... thats sucks.
