I got a set of TTR poly trans mounts my question is do you reuse the bolts, i am asking this because the  bolt i took out of the old one is way smaller than the hole in the sleeve they send with the mounts.  It would defete the purpose of the mounts if they were able to move around the bolt that holds them in if some one can answer this for me i would appricate it thanks
Well I emailed TTR and they said that the aluminum sleeve hole is supposed to be bigger if it is too small the bolt won't fit.  When tightened down the frame mounts will pinch the sleeve and it will not go any where
