Looking for any information or help i have a 1995 convertible sunfire that has a 2.3 quad 4 engine it it with an automatic transmission , i pulled the trans out to put into a 1999 cavalier with a 2.4 twin cam had installed and been running with no issues ,my question is what transmission is this? it has a vented fill cap on it ,and a blocking looking side cover that seems thicker/stronger then the valve body covers on the 2.4 ....it was a direct bolt in and same axles, just changed the shift linkage mount  ......cant seem to find any information it with research and no tags/numbers basically just looking for what it is or what gear ratio would be in it ,as it seems to pull a lot harder in low gear then the 4t403 that was in my 99 thank you in advanced
It probably has a lower final drive since the convertible is a heavier car.Its a 4t40e
