I was wondering if next friday I will be the only guy on here with 18x8.5" wheels on their Cavy? Just curious.
now there is your claim to fame !
8.5 is way too wide. Good luck with rubbing.
CAC2004 FSS#1, 2003,2004 Atlantic FSP #1, 2004 Overall Atlantic #1
no theres other people w/ that
No its not too wide, i know of a sunfire that has them on his car. Depending on the offset and the modifications done to make it fit.
I just wanted to make sure I wasn't the only "retard" that was running wheels that were "too wide" for my car.
"Too wide." Ha.
Anyone want to show their 8.5" wheels?
i have 17x9 rear and 17x8 front
^^ pics, cuz i find that pretty hard to believe
[quote=ßãggéÐÇåv98  (Ûñqùðtäß£è Øñé)]^^ pics, cuz i find that pretty hard to believe
1998 Chevrolet Cavalier Z24
Body Style: Coupe
Color: GREEN
Engine: 2.4L DOHC "Twin Cam"
Transmission: Manual
Interior: TAN
Purchase Date: N/A
Purchased From: DEALERSHIP
Build Date: N/A
MODIFICATIONS
Engine:
    * NONE
Suspension/Wheels/Brakes:
    * DROPPED
Interior:
    * NONE
Exterior:
    * 2000 PAINTED TOYOTA TAIL LIGHTS
Audio:
    * NONE
Miscellaneous:
    * NONE
Im calling
 ... He would have atleast filled it out in his registry.
TOYOTA  24 S wrote:i have 17x9 rear and 17x8 front
I'm planning on running 225/40R18's on 8.5's in front and 235/40R18's in back with a 9. I know it's possible... but I'd like pics as well.
It's not a matter of being too wide. There's no such thing as too wide... you just need to make things fit.
sorry about the registry i havent updated it yet but ill get pics soon to show .they are impul rs wheels i had advans generation 2 but i got rid of them they were 17x8 seeing that i had a  lil bit more space to fill i decided to go with 17x9 i put a 25mm spacer on both front and rear the fronts are 17x8 and im using toyota cavalier fenders ill update my profile sorry guys.
How does it help to have wider wheels on the back if our cars are fwd? just wondering not trying to bash anyone or start crap.
ak z24 wrote:How does it help to have wider wheels on the back if our cars are fwd? just wondering not trying to bash anyone or start crap.
So it looks better! our cars are more narrow up front, and I believe our track width is wider up front too.  So it automatically makes our rears look more inward towards the car.  A wider wheel in rear will make it look more even.
Staggered fitment is what they call it.
My Myspace Page
James (ROLN19S) (JuicyJ) wrote:ak z24 wrote:How does it help to have wider wheels on the back if our cars are fwd? just wondering not trying to bash anyone or start crap.
X2. There isn't really any performance benifit for FWD, it's mostly just for the look, and it does look good on our cars.
I'm witing for pics from  toyota 24s
I think that would look good
a 17x9+35 would definitely be possible in the rear... there's so much clearance... but I still want to se proof.
C:\Documents and Settings\HP_Owner\My Documents\My Pictures
hope this works but heres one picture of the wheels rear 17x9
20Rob05 wrote:James (ROLN19S) (JuicyJ) wrote:ak z24 wrote:How does it help to have wider wheels on the back if our cars are fwd? just wondering not trying to bash anyone or start crap.
it also means you can't get directional tires unless you want to have them dismounted and mounted every time you go to rotate them.
The tire size is 235/45/17 but i will be changing that all around. The rear is streched looks cool but id like it if it was a lower profile, and i do have spacers in the front and rear so if one looks at the toyota fender it seems to be more clearence for a wider wheel in front or a bigger spacers. when i had the stock fenders the 17x8 did stick out . they are hub centric spacers . i think its possible to go with a 9.5 inch tire in rear and 9 in front maybe i should put the 9 in the front to see what it looks like. different offset but ill see if it works.
Very nice. Very very nice. What kind of wheels are those?
What size spacers did you use for the rear Toyota 24 S?  I need some bad for mine.. I was thinking of going with the 1/4 thick spacer.
my offset is i believe positive 38 i went with a 25mm or 1/4 inch  spacers all around .I got these from a company called TC sportline. These are not the spacers by themselves it comes attached with studs and its hubcentric. I put the other kind of spacers and my wheels didnt go on evenly. its not noticible when one looks at it but when i took my wheel off there was stress on one of the studs and broke off. so ill never install those again for safety reason i believe eibach sells some like the TC sportlines i know they come in bigger sizez which i migh go with in the front to fill in the gap or just put the rear 17x9 in the front and hope to find a 17x9.5 so i can put on the rear and keep the 17x8 as a spare.
Thx.. Since you noticed stress.. Im not sure if I wanna get those spacers.. I just wanted to see if there was a good spacer out there that makes a noticable difference and that you dont have to get longer studs.
Thanks for the info.
I have a set of 20 x8.5s going on in spring should be here next week sometime 18x8.5 isnt that big lol
