Is it true that you need to trim your axle bolt down to fit aftermarket wheels??? i am getting some mr7's and i would like to put the cap on but i heard you need to grind down that bolt... i havent got the wheels yet but i would like to know if this is true... i dont have a grinder so this will be a problem.
http://www.jbodytuner.com
^^ The real jbody store and forums!!!!!
lots of people have mr7s i cant imagine you need to grind down the axle, frankly i wouldnt recomend it either
depending on the style and offset  of the wheel, the the front bolt sticks out some and might not let u put the centercap on.  only solution is to cut/grind the bolt some.
ya thats what i was thinking... what offset is like the limit before you have to cut or grind? like what size do i need to watch out for?
you do NEED hub rings. metal ones can rust, making it difficult to remove the wheel. plastic ones are available, and are what i would use.
according to the summit website the rims has a bore of
2.86200 inches = 72.6948 millimeters
will the rings that i linked you guys to fit?? it is slightly bigger but it says it's for motegi.. the rings are
lokl thats wierd.. the rings are 73.1
there are many different sizes of bores.  im not sure what motegi uses, but you do need to get the EXACT size.  i think summit might have the wrong bore listed on there.  also, there are gorilla hub rings on summit, so there's another place you can buy them from (although, they might have to be custom order and you'll have to use gorilla's website to find the part numbers).  but i'll tell you right now that 16" aftermarket rims aren't worth buying (go at least 17"), and motegi mr7's are SOOOOOOOOOOOO outplayed that you're gonna get a lot of ugly looks for them, and once you see that even grandma's drive on mr7's or look alikes, you're gonna regret buying them.
well i live in maine and there are like nobody around here with any kind of aftermarket rims... and i already paid for them.. just waiting for shipment.
i mean around where i live.. in winslow.. i very small town.. with a bunch of people that dont really care about their cars
where do you live?
yes the lugs you need are 12 x 1.5.  i prefer mcgard though.  best lugs i ever owned
i would only go with gorilla or mcgard.
can you fine me a set on ebay?? chrome.. i have looked and they all say gorilla and i dont know what they are suppose to look like.
50 ouch...
i actually thought those were more like 60-70?
regardless, you can use these from summit racing.
GOR-21133HT
