I am doign some major body work and without giving it completely away I need some wheel spacers....
How wide can I go on factory studs? I dont need much I have seen 3mm 5mm? Any input on how much i can go before needing the kind that bolt on with new studs?
ShowFire
What kind of rims?
I'm thinking you can get away with 5mm, provided the spacer doesn't put all the wheel weight on the studs (i.e. it acts as an oversized / flat hub-centric ring).
The only thing you have to keep in mind is that your suspension geometry will be way off, so this will be strictly a 'show' type of dealie.
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
I am going to be running a 19x7 with a 40 mm offset. 215 35 tires
Thanks!
ShowFire
