I am just gathering information....
Say i was looking at a set  of wheels they came in
Size: 16 x 7
I know what this means
Bolt Pattern 5 x 100
Offset +40
But with a +40 offset would this put the rim towards the fender or towards the strut
The car would be on coil overs if thats a factor
Also tires
i know the stock size for a 16" rim is 205/55/16
but to have a wider tire could a 215/50/16 passably a 225/50/16?
the rim would be fine.  the lower the number for the offset the farther out towards the fender the wheel will sit
as for the tires size, im too lazy to look it up on a tire calculator but you can do it that way and it will tell you which tire is the closest to a 205/55/16.
go w/ a 225 tire.  cavaliers recommended offset is anywhere from 35-45. so a 40 will be perfect.
WiGM-Tuners member.
