Well I got some 17x7.5 rota sub zero's and the hub bore is to small and when I put the wheel on the center car pops off because the axle is too long.
How can I bore out the hub? What should I do about the center cap?
13.520 @ 98mph! 220whp 234tq
you will either need to go get the rotas machined or get some small spacers like i did. and for the center caps you will have to cut the spindle down. i just didnt run them at all .
Any more pics of the rota's on your car?
So you ran spacer's front and back without having the center's bored out?
Nice.
I got the silver ones with the polished lip.
Payed $85 bux and a digital camera for them. Gotta love swap meets.
sweet... i thought of getting some more rotas.. i put about 10k on the rotas with the spacers.
and im pretty sure i had 17x7.5s offset was mabe 35mm dont remember fitment for a WRX.
Edited 1 time(s). Last edited Saturday, May 01, 2010 7:57 PM
Mine are 45mm offset.
So where could I get them machined?
check around locally to you ..
Just search for a machine shop?
yup... or even a wheel shop that can fix wheels
Alright I will look around.
How would I cut part of the axle off without messing up the thread's?
i wouldnt... just dont use the caps or mabe try to get some other rota caps with a deeper cup.
Can't find them.
that shop is 30 mins away from me. lol i would call them and ask for the depth of the cap.. and compare it to yours. and also ask if they would fit your rota.
lol ok.
I had a set of Rota's hub bored by a machine shop. Just call around, you'll find a place.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
if you cut the axle down with the axle nut still in place, when you run the nut off, it should clean up the threads.
I was lucky that mine have a 73mm center bore, so I used a hubcentric ring. I was never able to get the stock Rota center caps to work on the front. I have center caps from another rim that work on the SubZero's ( just cant remember what they are from )
Just run them without the center caps
Jason
99 Z24 Supercharged
157hp/171tq - NA
190hp/170tq @ 6psi
LG0/LD9 for Life
Use different caps all together?
WiGM-Tuners member.
