17s and 16s - Wheel and Tire Forum
17s and 16s
Tuesday, September 29, 2015 4:12 PM
So on my new cavy I want to get new tires which I plan on procuring from discount tire direct. Now wider tires means more rubber on the road which means better traction, what I had in mind was to have 225/50/16 on the rear and 225/45/17 on the front and I don't want to go larger than a 17 on the rear or front. Would that provide better traction and still be somewhat accurate for my Speedo? I read the effects of upsized tires but didn't see the answer to my question or I did and just don't realize it.
What I want is traction and stability over accuracy of my Speedo but I don't want to be going 60 on the Speedo and actually only be doing 50. Or would it be better to just have either the 225/45/17 or 225/50/16 all around to achieve the traction/balance I want? I do plan on lowering my 04 coupe about 2" so that is also a factor but that will occur after I get new tires/rims as the tires on her currently are sad.
Re: 17s and 16s
Wednesday, September 30, 2015 6:38 AM
I would stick with the same size wheel/tire all around. The sidewalls will react differently during cornering and could potentially cause an unsafe handling condition of you run two different size wheels.
Re: 17s and 16s
Wednesday, September 30, 2015 7:43 PM
Ah, did not even think about that as a possibility. Which size would you recommend then?
Re: 17s and 16s
Wednesday, September 30, 2015 10:09 PM
16" would be a better ride but the 225 45 17s are what allot of ppl are running.
ReD RaiN
Re: 17s and 16s
Wednesday, September 30, 2015 10:54 PM
Elaborate on better ride, like smoother & more stable? Because what I plan is to lower Jezebel(my 04 cavys name) 2" and have ttrs dog bone, ecotec upper mount and solid 4t40e mount so would the 16s still provide a better ride despite all that? If I go 16s I'll be getting these rims http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-100&fl=&yr=2004&pc=54231&counter=1&wd=16&rw=7&vid=007681 17s would be these rims http://www.discounttiredirect.com/direct/findWheelDetail.do?bp=5-100&fl=&yr=2004&pc=46995&counter=2&wd=17&rw=7&vid=007681 which rim wise I prefer the white but in the end what will provide better stability is the winrar.
As for tires I think either the geostar remex RX-615, Cooper Zeon Rs3-a, or the Kumho Escta 4X ku22 in 225/50/16 and for 225/45/17 I think either the Kumho Escta Asx, Hankook Ventus V2 Concept 2 H457, or sentury uhp. Not too pricey but all look good, rated high and the tread seems to be rather gripping I suppose is the word I am looking for.
Re: 17s and 16s
Thursday, October 01, 2015 7:38 PM
16's have more sidewall so they won't ride quite as harsh. 17's have a shorter sidewall so steering inputs will feel more direct.
Re: 17s and 16s
Saturday, October 03, 2015 10:50 AM
I see, 16s it is then. Thanks guys
