Slicks or Street Tires: keeping drivelines alive - Wheel and Tire Forum
Thursday, August 25, 2005 1:22 PM
Slicks or Street tires? What's best for driveline durability? I'd like to offer some information here that I think you will all find useful, and hopefully thought-provoking. Any and all replies are encouraged.
First, a bit of wisdom regarding slick use...the prevailing philosophy is that slicks are harder on driveline components than street tires. This is not neccesarily always true. Slicks, while they certainly can transmit more continuous torque to the driveline than street tires, do have one major benefit...they don't impart the torque 'spikes' that street tires can, and it's these 'spikes' that damage more axles and differntials/transaxles than many imagine. Where do these 'spikes' come from? Two conditions: 'spin and hook', and wheel hop.
In 'spin and hook', the street tires spin when power is applied, and can spin VERY hard. When they do suddenly hook up, the momentary torque transmitted can be many times the continuous torque potential. Where does all this momentary torque come from? We all know that energy can't be destroyed, it can only be converted. The kinetic energy of a wildly spinning driveline is amazing. It's all one big flywheel, and a very heavy one at that, when you add the weight of all that is spinning (wheels, tires, differential, axles, transmission shafts/gears).
Ever feel the 'surge' forward that occurs when the tires suddenly hook and stop spinning? That's the conversion of all that kinetic energy into movement. Now, another thing is also happening. Not only is the flywheel effect described above at play, but what else happens? The engine, along with its flywheel and clutch assembly, is suddenly decelerated massively, thus the RPM drop when the tires hook up. More energy we cannot destroy! So, now, not only does the driveline have to put up with the sudden flywheel effect of itself decelerating, its also getting yanked on through the other end (input) by all that energy of the sudden deceleration of the engine and flywheel/clutch. Add to this the weight of the vehicle being surged forward, and you can imagine how much momentary load is seen. Every item in your driveline has a torque limit, and if that limit is exceeded even momentarily, the damage can be instant.
Slicks typically won't allow these severe 'spin and hook' issues, and thus, can actually reduce the attendant strain on the driveline.
The other major culprit is wheel hop. Folks, do NOT ever allow wheel hop to occur. If you feel it beginning, lift off the throttle and push the clutch...NOW. Wheel hop is a smaller version of the phenomenon described above, but in a way, it's even worse...with every 'hop', the over-torque occurs. If there's ten 'hops' before it stops hopping, which can take but a couple seconds, that's ten death-blows to the driveline.
Slicks tend to eliminate wheel hop due to the 'resonance' of the floppier slick tire as compared to a stiff street tire. Taken another way, the slick acts as a shock absorber, stopping the wind-up and release of suspension that causes wheel-hop.
I'll also share an interesting anecdote. Back in the day when we were first turbocharging Neons, we regularly were told that the drivelines would NEVER hold up. We were told, "Why, my buddy with his 14 second Neon busts axles all the time! How could it ever hold up to double the power?"
Seems logical on the surface, sure! But what the fellow didn't know are the real reasons why his buddy was shredding axles. Yep...it was all about 'spin and hook' and wheel-hop.
We proceeded to run as fast as high 11's on stock axles with slicks before we needed to upgrade the axles. And get this...we ran high 9's on a stock transaxle-equipped (Quaife differential) drag Neon with 600HP, and did it repeatedly!
Further evidence is shown in the very fast Hot Rod (NHRA) or Pro 4-Cylinder (NDRA) classes of racing. Did you know that there are Hondas there that run in the eight-second zone on huge slicks with warmed-over STOCK 5-speed transaxles? Sure, they put in better diffs and axles, and don't get many passes off a stock-based trans, but they do it...all the time, with power in the 1000HP range.
One other aspect that leads to early stock differential failure...one-wheel burnouts. Whatever you do, do NOT participate in this ruinous activity! I have been at the track and seen cars doing this so many times, and I cringe...why, sometimes I can even hear the spider and side gears HOWLING from 30 feet away while this is going on!
Why does this kill diffs? Bear in mind, the stock diff is designed to do one thing...enable the tires to turn at different speeds to allow you to turn left or right without binding. The speed difference between the axles under this intended use of the diff is, at worst, approaching 2:1...the diff gears barely even turn. What do you think those gears are doing when one wheel is going 60MPH and one is standing still in a one-wheel burn? These gears don't even have real bearings in them, for they should not need them...the lubrication problems alone from one-wheel burnouts can trash a diff faster than you can say 'Phantom Grip'!
Does a product such as a Phantom Grip strengthen the differential? In straight ahead acceleration with both wheels hooked up, no. FWD vehicles have one inherent advantage over their RWD cousins with engines in the front of the car...natural engine torque reaction does not tend to reduce pressure on one wheel, encouraging the other to spin. Thus, a FWD car with slicks and a Phantom Grip is no durable than the same car with a stock diff. Slicks tend to ensure that both wheels stay hooked equally, so a stock diff on a car with slicks is not made stronger by the addition of that PG. However, a Quaife or PG is a real good idea on street tire cars that drag race, if only to discourage one wheel from taking off and spinning much harder than the other, whether in a burnout or on the track.
But there's something no trick diff can ever do, and that's change your driving habits. If it spins, LIFT. Get right back into it if you like, but never keep your foot mashed to the floor unless you like buying driveline components with money you could spend on other things.
Bill Hahn Jr.
Hahn RaceCraft
World's Quickest and Fastest Street J-Bodies
Turbocharging GM FWD's since 1988
www.turbosystem.com
Re: Slicks or Street Tires: keeping drivelines ali
Thursday, August 25, 2005 1:27 PM
wow...another great read. i was just talking about traction issues with you and now this....could this be a hint to buy slicks?
5K PB: 24:50
10K PB: 54:26
Thursday, August 25, 2005 1:30 PM
Good reading Bill!
Thursday, August 25, 2005 1:40 PM
yup , sudden shock loads are what kills parts
gotta love watching spider gears explode , lol
Friday, August 26, 2005 10:12 PM
great info as always bill
The one, the only, ME.
Wednesday, September 07, 2005 10:09 AM
bump
Bill Hahn Jr.
Hahn RaceCraft
www.turbosystem.com
Saturday, October 01, 2005 5:25 AM
Very great post!!!!!!!
Sunday, October 02, 2005 9:00 AM
Good read, thanks for taking the time to type that out!
For Sale:
Getrag '00-'02 2.4 8000kms $800
Saturday, October 15, 2005 12:19 PM
nice info bill.
13 psi and climbing......
Saturday, October 15, 2005 8:42 PM
great stuff bill!!!!!!!!!!
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Friday, December 23, 2005 4:25 PM
Guy's I have to say this forum Rocks. I am a member of alot of Forums but the people here seem to be much more knowledgable.
Motegi Racing Wheels American Racing Wheels Nitto Tires
Sunday, December 25, 2005 10:49 PM
Thanks for the info, learn something new every day!
Your V 8 may have horsepower but mine has horsepower and better gas mileage.
Tuesday, January 10, 2006 8:51 AM
Great info friend. A question DOT approved tires suffer the same problem?
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
Friday, January 20, 2006 7:27 PM
good info!
Thursday, April 13, 2006 8:02 PM
ive been wondering? do 03 cav ls sports have a limited slip diff because ive never had a one wheel burn out, is it bad to spin tires into 2nd and 3rd gear a little(kinda like a chirp)
im used to racing slapshift autos not 5 speeds.
Thursday, April 20, 2006 1:38 PM
No, your car does not have a limited slip. Most FWD's like Cavalier are actually pretty effective at spinning both tires, but problems can occur under certain conditions. The most common issue is excessive stick/insufficient water under one tire during the burnout, which sends the other tire a-spinnin while the 'stuck' one just stands still.
Just always be sure that both tires are spinning, and you'll be good to go.
As for the spinning into 2nd and 3rd...are you referring to doing this during a burnout, or under some other condition?
Bill Hahn Jr.
Hahn RaceCraft
www.turbosystem.com
Sunday, May 21, 2006 7:39 PM
Whats your thoughts of drag radials? I cant run slicks in my class and desperately need them. I want to run stock 14 inch steelies, with drag radials whats a good size for me?
Monday, December 11, 2006 2:08 PM
Hey I am wondering what would be the best tires to run for Street drag tires, not that I want them for racing illegally just so i don't have to change out rims when I get to the track even though I might anyway
96 CAVALIER Z24 UNDER CONSTRUCTION
Saturday, August 04, 2007 4:21 PM
I just want to add my two cents
When i ran my drag radials i rarely did a burn out, for the fear of the one wheel peal. I would go around the burn box and pull past all the hot burnuot rubber and do a few dry hops, basicly to knock off all the stones/dirt off the tires, then im good to go. Just reciently i bought a Team Green LSD insert from Brian, wow really no difference on launch for my car (had welded spider gears before, no differance) but just that little bit that the LSD offers, now im doing 2 wheel burnouts, even entered a burout contest, did well but lost to a one wheel peal car, but that was ok, he blew his one tire because of it. Now im Hoosiers 225 50 15 with only one weekend on them seam to be doing well. lookin to better my 1.85 with my new tires
Good Luck
-Ben
Overall Best times
60' - 1.857 (6/24/07)-(Drag Radials 205-50-15)
330' - 5.552 (6/24/07)-(Drag Radials 205-50-15)
1/8 - 8.690 (7/22/07)-(Conquesrt Radials 195-70-14)
M.P.H. - 81.87 (7/22/07)-(Conquest Radials 195-79-14)
1000' - 11.274 (7/22/07)-(Conquest Radials 195-70-14)
1/4 - 13.442 (7/22/07)-(Conquest Radials 195-70-14)
M.P.H. - 104.08 (7/22/07)-(Conquest Radials 195-70-14)
** ALL MOTOR **
* 181whp @ 7600rpm *
Website: www.benwenzeljr.com
Wednesday, October 03, 2007 12:30 AM
so any kind of wheel spin can break stuff? is this true for automatics too. i have the gm supercharger kit and a auto with the stock radials the tire break loose often im i hurting any thing when this happens?
Wednesday, October 03, 2007 12:33 AM
Monday, July 24, 2017 1:46 PM
Tires with combination of wheels
