okay i have a 97 Z24 gauges cluster is messed up well mainly the tach on the cluster looking for the best and cheapest way to install a tach  any help would be appreciated
IF you got a Pick-N-Pull in your area I would suggest going there you can pick up a cluster for around 20 bucks and Wed. is half price everything. I bought a hood fender and door for 135.00 in Feb.
Tinkles Wrote: Grab another 97 cluster.
i was thinking of doing that but i a buddy of mine is giving me his old tach and i was wondering if there was an easy way of installing it without buying an adapter, i have also noticed a fuse slot under my hood that is label tach
The easiest and cheapest way is to replace it with another cluster.  If you are dead set on using the "cheap" tach, then you are going to have to buy a tach adapter which usually runs around $90.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
You could find a used Autometer 9117 Adapter on eBay, they can be had for about $40. The fuse slot is useless since you don't have a Z24
Check with Summit racing I bought mine there for  40 or 50 bucks I think
i will look around on ebay and for the record i have a Z24
