I have searched a lot on this topic but haven't found anything on this, but would it be a direct swap for a dash from a 2004 sunfire to a 2000 sunfire, If not how much work would be involved.
ull def need the whole dash top to bottom and also the door panels same console n rears but should have no prob just removing and swapping since radio and hvacs and what not are all in the same places.
If you're only wanting the round vents all you have to swap is the upper dash pad, the new one will bolt right in.
I want your 04 dash and all that then if your cereal.
ECOtec DOHC
Way too much confusion in this thread.
yeah just swap the top pad and the steering wheel if you want the effect, i changed my top pad in my 95 without a problem.
i thought the was more to it
Nope the only difference in the top pad is the shape of the vents.  Everything bolts up exactly the same.
good luck with the radio swap..
AZ24Ncav wrote:good luck with the radio swap..
what radio swap? don't confuse him.
