how do i go about removing the "slider" thats located by the moonroof?
you know, the piece you can slide open or closed to let light in or out..\
thanks in advance
Grab it, pull it really hard until you hear a ripping sound and it comes off.
Just take the headliner off and see what its attached to. I have an aftermarket sunroof so I am not sure but I am sure once you take the headliner off you will be able to tell.
http://nwgme.org
i did remove it. its too dark to go out there now but i can get some pictures.
theres a black "bracket" thing that holds it that has a screw and a bolt on each side. i thought if i removed those i could get it out but it didnt work. im just afraid to mess something up up there so i figured i would ask before i went any further.
there are four push slides two on each side of the the slider.  Open the moon roof  just enought to lift it and have about 4 inches from the front and you will see them push the pins in and lift up then remove by sliding it out the back of the moon roof
