Ok haveing issues with the dash paint is there a type of paint???or am i doing something wrong or what????? Please Help n let me know thanks Sean
Ummmm, it might help if you post what issues you're having. Peeling? flaking? Turns pink? Starts on fire?
perhaps it goes for a jog? who knows
1999 2.4L w/ nitrous
im starting fresh its just a stick dash im not doing the top part just pits and peices but it bloches up and it looks like crap...is it because im not priming enough????
how heavy of coats are u applying?
I put 1 Coat of primer and i think thats my problem...and one piece i did i put 1 coat of primer and 5 coats of the color and it still looks like @!#$...
Not sure where you live, but make sure its not too cold to paint, make sure the paint is thinned properly, and use several very light coats. Mke sure everything is clean. All that old Armor All and any other garbage on the pieces has to be removed completely.
yes clean whatever you are painting like your life depends on it. sanding if you are going that direction will take longer than you planned...so plan longer...lol and you must be patient with primer and waiting before you paint. 4 coats of primer or so is about what i did, and EVERYTHING IN LIGHT COATS. we dont wear no heavy fur jackets here. har har har
and yes, pics please.
make sure the piece is super clean, if its not the paint could be splotchy and it will peel off easily. really eaily. so clean it well. and 1 coat of primer? if your going to coat it completly you would need more then one coat, unles your laying the stuff on super thick. use several light coats of primer and then several light coats of your color.
http://www.flickr.com/photos/sndsgood/   https://www.facebook.com/#!/Square1Photography
have any of you ever heard of G2 interior dye? I used it on my entire dash and door panels a few years ago, got primer and paint, had no problems w sticking, peeling, rubbing off, sweet stuff.
i just used the vinyl/fabric paint from cdn tire, worked well
Making sure it is clean is the key to it all!
You also have to know how to spray....several light coats, dont go crazy with it, keep the temp good and as much dirt and dust away as possable to save sanding later and your golden!
"Hondas are like tampons, every pussy has one!!!"
