how high of a grit should i go when sanding my  cavy's hard interior plastics 600 grit maybe?
i used a wet sand type. @ 150 grit but then again i didnt sand mines down smooth i like the texture factory look but if u want it smooth go like 100,300, 600 wet sand also use krylon fusion or SEM paints neither require a primer but I personally primered with the krylon.
beer is like a chick.. well not really its just beer, it be cool thou huh?
sndsgood wrote:only need to go up to 300 or so to get it totally smooth. then primer with a high build primer, wetsand that with 400 grit, then spray.  i'd highly suggest have a shop spray it or using a compressor and gun to spray it versus trying to rattle can it.
exactly, the difference between rattle can and using an automotive spray gun is unbelievable.  try and get ahold of a spray gun or pay someone who knows what they are doing, itll be worth it...
id go 220 to get it all even then smooth with a 400. prime seal and paint, then be uber sexy and sand it with a 1500 and buff!
LNO95 wrote:would an airbrush work for interior parts? rather than air compressor?
it would take forever and a day...
i stoped at 400 and it was sweet! next time im gonna stop at 600
You CAN get just as good of a paintjob from a rattle can as you can an airbrush or gun.
You can even get HOK urethane in cans. If you don't have access to a spray gun, use what you can get.
I did this model car with a rattle can...NO clear, NO wax, NO sanding..nothing. Just paint...
My point is....it's more technique then equipment.
i do custom interiors all the time.....
easiest way to get it looking smooth, without using a hell load of time is to go 60 grit, 100 grit, 220 grit........then sandable primer......then 300+ grit, and youre ready to apply paint.
fyi:  this is not the fail proof way, as it actually requires alot more time, and a few more grits thrown in there.....but this works just fine for a non-show car...........
speed costs money, i have little money, so i have little speed.  Donations are appreciated =)
yeah thanks for all the advice im done already i used the real thing (air compressor and a real paint gun) it look s good. ill get some pics soon. oh yeah i sanded with 80 120 150 220 400 and then 600 then used adhesion promoter  after cleaning the parts then 2 coats of prime then 2 coats of paint and then 2 coats of  clear looks really good
i used 180 to smooth the bumbs on the steering collem and then used 320 to get it smooth.  Worked great for me
very well put wysiwyg. I also do all my model cars with a spray can, kind of makes me feel like a proefssional painter when I do them that way.
"All men are created equal, only a select few become firefighters"
LMFAO. Why are you responding to a 2 1/2 year old post?
I just saw the date it was posted  d'oh
