wrap dash in vinal - Interior Forum
wrap dash in vinal
Saturday, February 26, 2005 2:48 PM
has anyone out there wrapped the top part of their dash in vinal, if so how did u get it to stick and will ti melt with all the ehat comming up from the dash
Re: wrap dash in vinal
Saturday, February 26, 2005 6:57 PM
our stock dash is vinyl. and i would suggest having it professionally done cuz of all the curves of it, and if it isnt done right, it will wrinkle an look like s%$#.
this is my sig
Saturday, February 26, 2005 9:07 PM
I have done it a couple times before when i do custom interiors.....the main thing you want to watch out for is the type of backing that is on the vinyl you are attaching.
reason i say that is cause there are some with a elastic mesh type (and fyi, those are near impossible to stick correctly for a long period of time), and then there are some with a cotton type backing (and these eat the glue perfectly, and stick right into place).
you also want to make sure the piece you are starting with is easil big enough......i try to make sure they wrap to the underside of the top dash at least 6-9 inches.
most any spray glue type adhesive will work fine.....just use a ton of that stuff.....cause a slight mist will not hold.
speed costs money, i have little money, so i have little speed. Donations are appreciated =)
Saturday, February 26, 2005 10:02 PM
ive decided to wrap instead of paint my upper dash. when you wrap in vinyl or whatever do you wrap over the factory vinyl or remove it?
Can I wrap dash in VINYL
Monday, February 28, 2005 6:38 AM
depends how thick your replacement is.
<img src=http://www.krimotorsports.com/images/graphics/newjbosign1210.gif>
________<a href="http://www.krimotorsports.com?source=JBOsig"><img src=http://www.krimotorsports.com/images/graphics/krimotorsportsbluemini2.jpg>________
"Your Premier Source For Automotive Neon & Accessories!"
Re: Can I wrap dash in VINYL
Monday, February 28, 2005 7:03 AM
you don't really need to wrap it if all you want is a color change....
mine is dyed with Duplicolor Vinyl and Fabric dye.
take extra care during surface prep tho.
