I had great success painting my interior with Krylon Fusion. I did not apply a clear coat though. I know Krylon Fusion does not require a clear coat, but i was wondering how many of you guys actually used a clear coat and do you recommend it?
I just painted mine w. Krylon Fusion as well over the past weekend and into Monday.  I noticed it didn't require a clear coat, and I did not apply any.  I have 2 quick coats(one coat, then another after a minute like the directions say) and then another coat over it.  Then I sanded everything down(and in between), then put everything back in my car.  No problems so far, and I like it as-is.
Sam
Ban low-performance cars, not high-performance ones.
I used it on mine and it made a huge difference. People were asking me if i had fiberglassed it  cause it turned out soo shiny and smooth. I used about 4 layers of it.
Im doing everything in my car right now so its still underprogress.   However I did my fuse cover and it came out great.  I think what I used was tripple kyrlon finish.  Not exactly sure of the name but it def has tripple in it.  Make sure you don't put any pressure on it for atleast  2 days though after you put on your final coat or you'l be sanding it down again
.  Hope that helps.
Rich
I painted my grill on my car with it. Clear coat made it smooth and looks a lot better. Though   it's not nessicary.
I used the clear on mine and it looked smoothed and shinny.
I recommend you clear coat it. I used Krylon Fusion paint on my interior last summer and it turned out great, but I didn't clear coat it. Through the year the interior handle on my driverside has become discoloured because of the constant wear of opening the door and I'm gonna have to repaint it. So definately use a clear coat, just be careful because in my experience, CC is really easy to fu*k up.
yeah you will see a huge difference once its clear coated. do it.
i just finished my interior 12 hrs
  no clear coat for me.. i didn't want it to be too glossy
i also used a clear coat on mine with the krylon...looks so much more shiny..
Chad
be careful to use it at the right temp. or ull see it all "foggy" like on your pieces u spray.
Moms & Dads talk to your kids,before its too late,tell them to say no to aluminum wings.
