what did you use to change the color?
Looks really good!  I should definately do that this summer.  Did you just use fabric spray paint?
Yes....... I know that's not a lizard.
yep, just fabric spray paint, used about 4 1/2 cans of it (payed 5.99 a can at canadian tire), took alot to keep the tan from bleeding through. Also picked up new plugs to hold it up, instead of painting the orginals black, only a couple bucks and looks alot better.  Normally the stuff wears easily, but i figure on the headliner its not going to get much contact and also no sunlight to fade it
I just put in a black carpet on the weekend.  I think id really like to do this.
But,.....How did u get out the headliner ?  Did u have to bend it ? cuz id figure itd leave a crease.
Wonder whatll be different with a sunroof...
What did you do with your visors?
i heard u gotta remove the A-Pillars...if so, howd u do that ?  i tried pullin up them the other day while i was drivin...
I cant wait to do it this weekend, prolly changes the feel of the interior alot.  Does it make it feel smaller inside the car ?
ok first, you do need to remove the a-pillar covers, they just pull off, you dont have to remove the rear side panels, i just removed the hangers, then pulled them out a little just to give some room, then pulled the headliner forward towards the windshield, then it just goes out the passenger door.
Second, the visors, i spray dyed them aswell, the elastic on the drivers one is a pain, had to  do it again the next day after letting it fully cure, then i stretched out the elastic and did underneath it.
As for making the interior feel smaller, not that i've noticed
ok, how do i get the piece that slides under the moon roof out to dye it??
no idea, i dont have a moonroof, id assume you can take it out once the headliner is out
99firese wrote:Got bored yesterday so i decided to dye my headliner black (why gm decided to make them tan in a charcoal interior is beyond me) heres the outcome, much better in my opinion
They made them tan to give the illusion of more interior space.
Did you know - the Cavalier interior is actually roomier than the car that replaced it?
99firese wrote:yep, just fabric spray paint, used about 4 1/2 cans of it (payed 5.99 a can at canadian tire), took alot to keep the tan from bleeding through. Also picked up new plugs to hold it up, instead of painting the orginals black, only a couple bucks and looks alot better.  Normally the stuff wears easily, but i figure on the headliner its not going to get much contact and also no sunlight to fade it
Actually, If you preped it right, you would only need 2 cans, And it doesnt wear  badly at all if you scotch gaurd it after.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
i have the sunroof/moonroof on my z24 and i have not quiet yet figured out how to get that piece out....i am painting/dyeing my headliner i am on 1 can and it looks good....will pick up a second though cause some spots are a little light where i ran outa paint.....but atleast 2 cans minimum is needed.....
what is this stuff u talk of for after u change the color?
actually the sun roof piece will come out very easy
there is 4 little snaps that hold it in , you push them towards the center , and pop it up and slide it out to the back and over the roof , with the sunroof in the vent position
Looks great.. makes me wanna do mine next week while I'm off.
I've got a few questions though.
Someone mentioned 'properly prepping' the headliner so you only use two cans. What do you need to do to prep it?
I know you don't NEED to remove the rear panels.. but what is involved in removing them (I'd like to paint them too while Im taking everything apart)?
My Car Domain Page
is this gonna look dumb if i got a tan interior with a black carpet and black interior pieces ?
I did the same thing... went and got a graphite headliner from the wreckers... $20 (Canadian.. what's that... $15 US?) Much faster than dyeing it.. especially the vis
I think there were graphite headliners up to 1998? Then they were all tan after that.... we had this discussion years ago.. I can't remember now.
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
