does sparco make steering wheel hubs for cavaliers?  i know momo does but i am having fitment issues with it in an 05 cav.
I believe they do.  Aaron from Turbo Tech Racing told me they did, and I think he might have the part # for it.  I could never find it when I searched.
Try checking with Aaron to see if you can get that #.
www.TaillightTinting.com   #1 SOURCE FOR VHT NITE SHADES
www.aPlusPerformance.com   BACK ONLINE SOMETIME SOON!
PHONE 763-682-9945
looks like the exact same thing as the momo hub.
why not just get the momo and save your self 10-15 bucks?
Portage, MI
Because he already has the MOMO hub but its not fitting on his car. I still think he doesn't know how to put it on right. Cause GM didn't change anything in 05. MOMO hub works fine in my 04.
Well if u get a sparco Hub, I will buy the momo off of you
tutus,
yes it is installed right by both myself and when i brought it to a shop to be installed.
attached is a picture on how far it slides down.  when you look inside the hub you can see the groves that the hub is suppose to contact they do not.  the hubs opening is lareger  and there is an air gap all around it.
i called momo up and their tech guys says their books only have up to an 02 listed.
It doesn't make sense. It works on my 04. I guess GM must of made some changes for the 05 or something.
Get on AIM if you can. Did you push the hub down to try to make the teeth reach?
titus,
sorry i didnt get back on here sooner, if your on tomorrow IM me on AIM at pacrossbow
below is another pic from straight on.  i am going to tighten it down on monday then back the nut off and see if the teeth engauged.
thanks for you help through this.
-robert
ok did some research...heres the deal:
cavalier without tilt wheel use the same shaft from 03-05:
03-05 shaft w/o tilt
cavaliers from 95-04, with tilt wheel, use the same upper shaft so once again the momo hub will work:
95-04 upper shaft
heres where they changed, the 2005 cavaliers, w/tilt wheel, use a different upper shaft (plus a different lower shaft), the momo hubs opening is too big for the shaft (picture below):
2005 upper shaft
What are the 05 guys doing then?
^^if you have a non tilting wheel its the same part # from 95-05.  according to gm parts they changed the tilt shafts from 04 to 05.
