Ok guys tommorrow I am laying my last coat of epoxy resin before I wetsand and add clear to my piece, what I was wondering was to get things perfectly smooth before clearing what grit did you guys start wetsanding with and then work your way up too?
Thanks.
Proud member of
JBOK (J-bodies of Kentucky)
ask john piparo
I would say Shifted is right. Also with your last layer it should be a flood coat to even anything out. Most of my parts never really have needed to be sanded, but just cleared.
My part I am doing has dried pretty level, but I like things to be as even as possible before I clear it. Thanks for the info guys I was looking at starting around 600 and its laid on pretty thick so I have room to work with.
Proud member of
your 1st coat should be pretty thin, just to soak up into the c/f.  then you should be using 1-2 flood coats.
When I sanded mine I started sanding with 400 gritt and worked my way up to 1500 wet sand.  Then I used some clear.
But like TRD cav fire said, depending how well your flood coats levels out, minimal or no sanding will be required.
TRD Cav Fire wrote:I would say Shifted is right. Also with your last layer it should be a flood coat to even anything out. Most of my parts never really have needed to be sanded, but just cleared.
^^thats basically it.  however i have had some projects that were so uneven that flood coats wouldnt level it out, so i took a sander and 60 grit to it.  then i worked my way up from there.  if your piece is pretty smooth, then 400-600 is where i would start.  good luck and post pics when its done
<img src="http://registry.gmenthusiast.com/images/tabasco/JBO%20ad%20banner%20brown2.JPG">
www.TabascoRacing.com
FOR SALE  email tabasco_ant@hotmail.com
Thanks guys, I'm going to probably start wetsanding tommorrow I didn't lay my flood coat on too thick but I felt it wasn't really needed needed, I only have a few high spots that need sanded down from where the resin dripped over the sides, so I'll probably start with 400 and work my way up from there and then use 600 on the rest of the piece.
Proud member of
i would like to see some pics of your project
