i took out my cluster and took off the silver backing on it, pulled out the green light socket, removed the light, got my new RED 194 bulb, cut it as needed, and put it back in, put the cluster back in the car, and it glows up like it always had, NOT RED... what do i need to do to make it glow red? and if it involves removing the needles, can i get some help with that? thanks all... later
to see if it worked... anyone know anything that could help?
my 99 Z24, i did exactly that^ and it dosent glow red wtf?
how red was the bulb in the first place? i'm switching all my guages over to Ultra Violet Led's it's going to look really good when i'm done
"I live my life a quarter mile at a time..." "for those ten seconds or less I'm free"
Maybe you need to change the bulbs for other color that mixed with the green mask of the cluster glows red. Could be an idea. But I don't know what about the needle glow color.
Regards,
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
what?^ lol explain that ish again?, it was just a regular 194 RED bulb
Friend, internal cluster bulbs should be normal incandescent transparent or white bulbs, right? Then green light of the cluster and yellow color of the needle are done by color mask inside the cluster. This mask should be green and yellow. Then maybe using some violet bulbs you can get the final red color you are looking for. Another idea is use red led bulbs.
Friend that is only an idea, maybe I could be wrong.
Regards,
