hope this ain't a repost, but anyways, can someone tell me how you get the c- clip off  on my 2001 cavi? i tried everything, and i can't get it off.  thanx
mgardone
I use a window crank removal tool.  They're available at most auto parts stores.
itsa repost x 1 billion
go to auto zone and get the window crank removal tool
some will say to just use a rag...but chances are...if your gonna take your door panel off then your gonna take it off more than once...so go the easy route and save yourself some frustration and time and spend the 3 dollars at autozone or pep boys or whatever for the tool
this is the window crank tool that i got, but it won't remove the c-clip, it should just slide out, right?
mgardone
its for the c clip
 my remover is black tho, maybe that makes a difference?
98' Pontiac Sunfire SE
but it doesn't remove the f**k'in c-clip, why not?????
mgardone
i assume it isn't working because YOUR doing something wrong, mine looks like that except its powdercoated black and works perfectly
I couldn't get the window tool that I bought to work either. Instead take a metal fork (dollar store or junk store) and break the tines off, leaving one. Bend that tine about 1/8-1/4" from the end (may have to heat to avoid breakage), and use that to snag the clip. A stiff piece of wire, screw driver, etc. may also work.
I use a bent awl works great
Donovan
umm no, actually, the groove is too wide and it won't catch on to the end of the c-clip, so i'm gunna have to find an alternate way to remove it.
mgardone
i got the c-clip off, but is it hard to get back in?? does it just pop right in?
I thought it was pretty easy.  Just used a flat head screw driver.  And putting the clip back it was simple, line it up with the handle and push.
 Asta La Vista OHV!!
Asta La Vista OHV!! Defined Parts
ok, everything is under control now, thanx for the help guys!
