sndsgood ~ I can base my opinion since my co-worker has a $40,000 GMC Envoy with loads of problems.  Just as many, if not more as me.  It doesn't matter if it is a low end vehicle or a high end.  They just don't make good quality in my opinion.  Maybe it is just bad luck for me, my co-worker and others that I know.  (There are a lot of other people that I know with GM vehicles that are not happy with them.)  If I spend $18,000 on a brand new vehicle, I should not expect this amount of problems.  I can see 3 or 4 issues, but 20+:
09/15/2004 459281 # N2030 - SWITCH - BACK-UP LAMP (MAN TRANS) - REPLACE 27031 miles
09/15/2004 459281 # N0912 - SOCKET, LAMP - EXTERIOR - REPLACE 27031 miles
07/24/2004 074640 # J6354 - ENGINE CONTROL MODULE - REPROGRAM 24412 miles
04/19/2004 443702 # J6440 - SWITCH, EVAPORATIVE EMISSION CANISTER PURGE VACUUM - REPLA 19984 miles
04/19/2004 443702 # C3348 - TRIM ASSEMBLY, FRONT DOOR - RIGHT - ONE PIECE - R&R OR REP 19984 miles
04/19/2004 443702 # K0600 - CYLINDER, ACTUATOR CLUTCH MASTER - R&R OR REPLACE 19984 miles
03/31/2004 441884 # H0720 - HOSE, BRAKE - FRONT - RIGHT - REPLACE 19288 miles
03/31/2004 441884 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 19288 miles
03/31/2004 441884 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 19288 miles
01/08/2004 433684 # E2147 - LINK OR BUSHINGS, FRONT STABILIZER SHAFT AT CONTROL ARM - 15658 miles
01/08/2004 433684 # N0912 - SOCKET, LAMP - EXTERIOR - REPLACE 15658 miles
01/08/2004 433684 # L1020 - CAP, FUEL TANK - REPLACE 15658 miles
01/08/2004 433684 # B4155 - MIRROR, OUTSIDE REAR VIEW - RIGHT - REPLACE 15658 miles
01/07/2004 433570 # E2180 - INSULATOR AND/OR BRACKET, FRONT STABILIZER SHAFT AT FRAME 15603 miles
01/07/2004 433570 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 15603 miles
01/07/2004 433570 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 15603 miles
01/07/2004 433570 # Y0002 - POWERTRAIN CONTROL MODULE - REPROGRAM 15603 miles
01/07/2004 433570 # N6600 - WIRING AND/OR CONNECTOR - BRAKE SYSTEM/TRACTION CONTROL - 15603 miles
11/11/2003 428505 # Z7902 - 2-DAY COURTESY TRANSPORTATION 12900 miles
11/11/2003 428505 # E1890 - FRAME, REAR - REPLACE 12900 miles
11/11/2003 428505 # B4156 - MIRROR, OUTSIDE REAR VIEW - LEFT - REPLACE 12900 miles
11/11/2003 428505 # C3128 - HEADLINING ASSEMBLY - ONE PIECE - R&R OR REPLACE 12900 miles
11/11/2003 428505 # K0060 - PEDAL, SHAFT AND/OR BUSHING, CLUTCH - REPLACE 12900 miles
07/17/2003 416364 # B4156 - MIRROR, OUTSIDE REAR VIEW - LEFT - REPLACE 8034 miles
07/17/2003 416364 # K0600 - CYLINDER, ACTUATOR CLUTCH MASTER - R&R OR REPLACE 8034 miles
07/17/2003 416364 # Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 8034 miles
07/17/2003 416364 # Z7903 - 3-DAY COURTESY TRANSPORTATION 8034 miles
06/18/2003 413333 # B4156 - MIRROR, OUTSIDE REAR VIEW - LEFT - REPLACE 6360 miles
05/15/2003 409834 # E2180 - INSULATOR AND/OR BRACKET, FRONT STABILIZER SHAFT AT FRAME 4744 miles
05/15/2003 409834 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 4744 miles
05/15/2003 409834 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 4744 miles
04/24/2003 407772 # H2640 - PEDAL AND/OR BUSHING, BRAKE - R&R OR REPLACE 3651 miles
04/24/2003 407772 # N4115 - LENS, INSTRUMENT CLUSTER - REPLACE 3651 miles
04/24/2003 407772 # B4156 - MIRROR, OUTSIDE REAR VIEW - LEFT - REPLACE 3651 miles
.....That was my point.  I don't expect a "Lexus" interior.  Just one that doesn't make noise or bounce up and down.  I just never saw a dash that  "jiggles" up and down.
