Ok so i did a bunch of my painting in my interior with rattl cans..duplicolor truck,van and suv paint to be exact. But i fount the clear coat to not be a smooth as id like. Im painting my other pieces blue with automotive paint and was thinking or either going over the spray bombed stuff with auto paint or just re clearing it with auto clear. Will this work and does anyone know if it will be ok or screw up? thanks alot..phil
hmm i used krylon fusion w/no clear coat, and its turned out pretty good but not finished..
If you spray over crap, regardless if its automotive body paint or clear coat, it will still come out like crap.
Strip the paint off, and try again.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
No i plan on sandin it smooth but im more worried about paint reactions..i know the steps to painting and all that but im not sure of compatability..the spray can says its a acrylic laquer and im using a 2 part urethane clear.  phil
I use engine enamel, so the heat of the sun doesn't melt it or fade, works great!
NEW SIG COMING SOON FOR 07'!!!
i jsut painted my g/fs interior here is what i did it came out awesome:
sand down the parts with 600 or 1000 grit sand paper, then clean them with acetone to get rid of shaving and get rid of any grease or dirt on them, then apply a coat of kyrlon fusion, wait 15 minutes, apply another coat, wait 15 min and apply the 3rd coat, let dry for an hour and apply 3 coats of clear coat waiting 10 minutes between each coat
FuSiOn 04 wrote:i jsut painted my g/fs interior here is what i did it came out awesome:
One variation of this that was worked well for me is to use the Krylon as a primer, then spray over it with automative paint.  Krylon has proven (for me) to be a better primer than primer when it comes to plastics.
Doing it this way allows one to use  a wider range of colors.
thats a good point, in my case the sanding of the plastic helped the primer bond and i had no problems
